Old 10-04-2007, 01:13 PM   #1
furr980
Default Gear Selection
this winter i plan to build a pure stock elinimator nova. i was woundering what gear ratios i should go with in the trans and rear? heres some info on my car. if you need more please ask.
engine-350 2 or 4 barrel; 390/410 195/202@050 800-4800
trans-350 turbo
rear-8.5 10-bolt
weight-3214 (thats shipping weight)
tires-28-29.5x9x15 bias ply or radial i dont know yet which is the best for my combination.
furr980 is offline   Reply With Quote
Old 10-04-2007, 01:20 PM   #2
Daran Summerton
Daran Summerton's Avatar
Liked 66 Times in 37 Posts
Default Re: Gear Selection
Is this a 69 or 70? It matters on the 2 Barrel combo - which is a good combo.
Gear as tight as you can unless your driving it in - then 4.11 is about max on the freeway.
Daran Summerton is offline   Reply With Quote
Old 10-04-2007, 05:34 PM   #3
Joe Marcinowski
Joe Marcinowski's Avatar
Liked 33 Times in 15 Posts
You may want to check with IHRA on your cam specs. You may be pleasantly surprised by the duration numbers. I would also get the valve spring pressure from them as this was my limiting factor when I ran Pure Stock. When you get these figures, it will be easier to choose a convertor and gearing.
Good Luck,
Joe
Joe Marcinowski 3377 STK
Joe Marcinowski is offline   Reply With Quote
Old 10-10-2007, 06:04 PM   #4
furr980
its a 73. i will ask for the spring numbers. im trying to find tranny gears and rear gears to run. i know they are out there, im just not sure as to which one. thanks for the help so far.
Old 10-11-2007, 09:20 AM   #5
Michael Beard
Michael Beard's Avatar
Liked 13 Times in 9 Posts
I'm putting new 'shoes' on the car at Rockingham. Might not be a lot left on them, but you can try my 9x29.5 M/T radials then. Radials must certainly be the ticket for a Pure Stocker!
Old 10-13-2007, 12:01 PM   #6
Joe Marcinowski
furr980,
Join this group, http://sports.groups.yahoo.com/group...OCKdragracing/. You'll get plenty of help from these guys. The 29.5 Mickey T radials were a .10 faster on my Pure Stocker in a back to back.
Later, Joe
Old 10-13-2007, 03:17 PM   #7
Mark Lewis
Liked 207 Times in 44 Posts
I would put a 2.75 gear in the trans and a 4.88 in the rear running radials. You might want to check cam specs on the 73 and 74 . One had a optional calif cam with more duration,401/401 lift, if available I would use the 4bbl.
Mark Lewis is offline   Reply With Quote
Old 10-13-2007, 03:31 PM   #8
G Schenck
Liked 81 Times in 35 Posts
8.5 10 bolt >>>>>>>>>> you will be limited to a 4.11 I believe.
Greg
G Schenck is offline   Reply With Quote
Old 10-24-2007, 06:18 PM   #9
furr980
thanks guys for all the great info. thnaks michael for the radials, ill defineatelt be testing with them. mark, where can i find that optional cam you were refering to.
Old 10-24-2007, 07:15 PM   #10
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Thumbs up Re: Gear Selection
the 74 is the one that has the 401 cam....also an 8.5 rearend will be fine in a pure stocker...you can get up to a 5.38 ring & pinion.....my cutlass has an 8.5 with a 5.13 gear & i've turned as good as 1.61 60's with it.
