Old 05-17-2019, 11:26 AM   #1
dlv4540
Liked 2 Times in 1 Post
Default 1970 396-375HP L78 Engine
396 4 bolt block casting number 3969854 dated H-20-9 stamped T0822CKO 10W121987. This block is a factory .030 block and has been cleaned and magged with two sleeves installed due to hairline cracks and was also pressure tested and fitted with new brass freeze plugs ready to build. I have the 11 to 1 pistons and rods, 3964291 heads dated F-6-9 & F-18-9 cleaned and magged with hardware to build, 6223 steel crank turned .010 just needs polished and the factory 8 inch harmonic balancer 3870325. Can ship if you cannot pick up and have all paperwork on machine shop work done. 330-770-2517 for any questions and will do $3500 shipped anywhere in the USA.
dlv4540 is offline   Reply With Quote
