Old 05-07-2019, 12:17 PM   #1
Bobby DiDomenico
Liked 101 Times in 52 Posts
Default Need a 12v bulb for 120v night light
Have a Marine transferring and his daughter found a night light she likes. It is a normal 120 volt wall socket outlet plug in and has the normal small night light bulb. Can anyone tell me where I can get a 12 volt version of those bulbs? Not familiar with the RV market. Thanks!
Old 05-07-2019, 12:49 PM   #2
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
Default Re: Need a 12v bulb for 120v night light
If it has a typical wall plug, isn't it going to get 120v one way or another? Either straight A/C or from the batteries through an inverter?
S/ST 51
S/C 53
Old 05-07-2019, 01:05 PM   #3
Liked 5,121 Times in 1,952 Posts
Bobby, A bit confused here. R/V wall plugs that look like household stuff are 110, either off the generator or shore power.
Interior lighting is 12 v and look like automotive bulbs..They can be replaced with LED bulbs for longer life and less current draw off the coach battery, or alternator, when traveling.
Old 05-07-2019, 01:24 PM   #4
Bobby DiDomenico
I'm going by what they told me, I agree I thought all the outlets were 120V, will verify.
Thanks.
Old 05-07-2019, 01:57 PM   #5
Mike Pearson
Mike Pearson's Avatar
Liked 1,926 Times in 579 Posts
Thanks.
Correct wall outlets will be 120V
Mike Pearson 2485 SS
