Liked 26 Times in 12 Posts
SBC SS Heads Up #416 good head 500.
Carb cover plastic 5. Hamburger GM starter Good 100. MSD 3 step New 50. MSD 3 step used 25. MSD Box 10 Plus & Coil 200. MSD Coil Pro-Power 40. Canton Oil Pan Screen New 40. 2- Hyercoils springs #85 2 1/2 ID 20. LT1 guide rockers- poly locks 7/16 balls & studs 80. Childs & Akery Piston ring installer bore 4.310 25. Ram GM short throw out bearing New 20. Moroso motor mounts #62500 New 15. Moroso steel trans mount 10. Liberty Trans Mount Slider Kit 100. Nascar air cleaner base & element & spacers new 40. Moroso air gauge 0-15 20. RCI Full Face Helmet White M2010 Med & carrier case 150. Fuel Filter assy BG5000 2 filters 50. Header Collectors 2 1/4 - 3 1/4 Coated 50. Phone 740 579 1111 e mail blendzall@att.net Thanks Larry Last edited by lareagle; 05-16-2019 at 02:55 PM. Reason: Mark SOLD on those that already SOLD |
Liked 586 Times in 162 Posts
Hi Larry, I'm interested in the accusump setup and, adjustable guide plates
Do you ship and is PayPal acceptable? I'm in Commack, NY 11725 Thanks Rich Boyle 631461-6761 |
Liked 6 Times in 3 Posts
Hi Larry. What parts are still available ??
