Old 10-02-2007, 08:06 PM   #1
cd1892
Default Competition Eliminator - C/Dragster
C/Dragster, 238? Mike Bos ? Chassis Craft, Liberty Pro-Stock Z series 5 speed w/mag case and single button air shifter, 8? dual disc L&T clutch w/142T flywheel, Trick Titanium bellhousing, MW center section, Richmond gears, Strange axles, titanium studs w/alum lugs, coated titanium brake rotors, Aerosport wing, Racepak SC1000 w/3 rpms, 8 egt?s, fuel psi, oil psi, vacuum, MSD 7AL3 ignition, ACD shift light control, Stroud chute, Impact belts, Monocoque wheels, Aeromotive fuel system, engine mounts for short deck or bowtie sbc, Spitzer carbon fiber air scoop, plenty of chrome and polished aluminum. Well maintained, clean and race ready. Runner-up 2004 Toyo Nationals at Reading, PA, Runner-up NHRA Division 1 LODRS event at Numidia, PA, Best Engineered 2006 Jeg?s Northern Sportsnationals. Suitable for Competition Eliminator, Top Dragster or bracket classes.
341cid GM short deck sbc, Slawko wedge head, HRE manifold, Breshear dominators, Winberg crank, MGP rods, BME pistons, Total Seal ring package, Bullet cam, Jesel valvetrain & front drive distributor, Stef dry sump pan & tank, Dailey 6-stage pump, MSD crank trigger, steel Jet-Hot coated primaries w/Burns Stainless merge collectors, driver side starter for 142T flywheel. Engine has 19 runs and dyno time since built.
342cid GM bowtie sbc, Slawko wedge head, HRE manifold, Bryant crank, MGP rods, BME pistons, Bullet cam, Jesel valvetrain & front drive distributor, Moroso wet sump pan, Peterson external pump, Star vacuum pump, MSD crank trigger, steel Jet-Hot coated primaries w/Burns Stainless merge collectors, driver side starter for 142T flywheel. Needs freshened.
Spares include;
8? L&T discs & floaters
7.5? RFE dual disc clutch w/spare discs & floaters
Transmission gears for pro-stock Z trans or old style welded spline assemblies
Strange aluminum center section complete w/Richmond gears
33x12 Goodyear USA (new) on 11? Monocoque
33x12 Goodyear USA (old) on 12? Monocoque
33x14 Goodyear Chile on 13? Monocoque
Many other spare small items available. Will sell car complete with any or all support equipment and spare parts or as a roller less engine, trans, clutch. Must sell car before any other items are sold. Photos available upon request, can also be seen on Autoimagery.com or Racingjunk.com ad #985207.
Chris Bozic
comp1892@msn.com
412.767.5562 after 6pm, please leave message.
cd1892 is offline   Reply With Quote
