Old 04-07-2019, 10:44 AM   #1
SDT1DYI
Liked 455 Times in 147 Posts
Default Gen 2 Camaro Front Shocks
Installing Double adjustable fronts. Using QA-1's. Does someone make a thicker mounting ring to weld to the bottom of the A arm to position the lower shock mount where you want it? The rings I have seen are all .250. The QA 1 shocks are a longer stroke than stock, so I have some length to play with. I would like to be able to adjust the shocks w/o having to remove the lower mounting fasteners.
Steve Teeter STK 6380
SDT1DYI is offline   Reply With Quote
