Old 04-02-2019, 12:43 PM   #1
Tjjr
Default Stock or super stock
I just bought a 2014 super cobra jet trying to figure what class I can fit into
It’s all stock
Thank you
Tjjr is offline   Reply With Quote
Old 04-02-2019, 01:21 PM   #2
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
Default Re: Stock or super stock
ClassRacerInfo
http://classracerinfo.com/CGPage.aspx?MFR=Ford&YR=2014&MAKE=Mustang
Old 04-05-2019, 03:22 PM   #3
Stick cars rule
Stick cars rule's Avatar
I have a question about this subject. I found my car in class racer info and it says the weight and index,ok.now I see that car got 20hp added a while ago.so where do you find the weight that the car has to be right now.more hp means more weight correct? car is a 2009 6.1 dp manual
Scott justo.
2009018 lc22r
Stick cars rule is offline   Reply With Quote
Old 04-05-2019, 03:42 PM   #4
kansas stocker
Liked 249 Times in 48 Posts
Go to the site Dwight listed click on the wt/hp for the your car and it will give you the three classes and the minimum weight for each.
Pete
kansas stocker is offline   Reply With Quote
Old 04-05-2019, 04:28 PM   #5
Stick cars rule
I found the car on the site.its a natural class fx/d min.wgt w/driver 3230.
my question is if I show up at a nhra race,the car with me in it has to be 3230. im just trying to figure this out so I can join in on the fun.
Scott justo.
2009018 lc22r
Old 04-05-2019, 07:24 PM   #6
Eric Merryfield
Eric Merryfield's Avatar
Liked 502 Times in 130 Posts
For f/d it's 7.5x 408 plus 170 for the driver for min weight of 3230.
Better to run it in e 3434 min 10.95 index to start till you learn the lay of the land and how much you need to spend to go fast. You can always pull some weight out Just my 2 cents I've been running a drag pak since 2010.
Eric
Eric Merryfield 1883 STK
Old 04-05-2019, 09:11 PM   #7
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
The shipping weight remains the same , even if the engine is refactored . What might change is the natural class . Shipping weight divided by the factored HP equals the natural class .
Old 04-06-2019, 08:51 AM   #8
Stick cars rule
thanks for that eric.i understand now.im waiting for track at Earlville to open so I can get on the scale and make first pass.
Scott justo.
2009018 lc22r
