Old 03-29-2019, 11:23 AM   #1
bert powell
Liked 34 Times in 12 Posts
Default Transmissions and BBC Super Stock Parts
TH350 low drag aluminum drums with updated ATI aluminum drum and 36 element sprag, TCI pump, TH250 gun drilled output and lightened sun shell, Stef’s pan. New JW bellhousing. Fresh rebuilt from Tim Sloan $2000
TH400 reverse valve body, alum drums, deep pan, locking dipstick, less than 100 runs since new, 30 since rebuild $900
402 BBC Diamond pistons and pins new/unused 4.191 bore .0415/.043/3mm coated top. Will throw in ring set with 4 dyno pulls. $600
JE 396/350 pistons (6), Crower rods 2.200/.927x2.500 (2 new), new pins. Need 2 pistons to complete $500
290 Heads Up heads, one repaired but would replace, with some valves $600
BBC 904 Isky lifters excellent condition $400
Misc roller cams std bore $150
12 bolt street gears 3.90 $75
292 head castings, 2 sets $250 ea set
049 head castings $300
236, 049 and 820 single castings $75 ea
454 cast cranks need turned $50 ea
Merlin intake, oval port, ported for super stock $400
Quay headers for 82-92 camaro 2 1/8- 2 ΒΌ step, dyno time only $400
82 camaro factory fiberglass hood, one corner needs minor repair $300
All plus shipping call or text 9 one 9 96185 zero 5
bert powell is offline   Reply With Quote
