Old 03-26-2019, 10:33 AM   #1
Jimmy D
Liked 17 Times in 3 Posts
Default Manley NexTek Polished Triple Valve Springs 221449P-16 NEW
Manley NexTek Polished Triple Valve Springs 221449P-16 NEW Set 16 Free Shipping
Set of 16 polished valve springs
Brand new in the original box
Free Shipping in the USA
$800 or best offer
May use PayPal or credit card on eBay
Here is the eBay link for pictures and to purchase:
https://www.ebay.com/itm/273768713756
Number of Springs Per Valve: Triple
Outside Diameter of Outer Spring (in): 1.677 in.
Coil Bind Height (in): 1.142 in.
Damper Spring Included: No
Spring Rate (lbs/in): 720 lbs./in.
Inside Diameter of Inner Spring (in) :0.632 in.
Valve Spring Style: Standard
Quantity: Sold as a set of 16.
Type of Spring: Triple without Damper
Color Code: Polished Finish (Red Stripe)
Installed Height and Pressure: 2.200'' @ 350 lbs./in.
Open Height and Pressure: 1.200'' @ 1070 lbs./in.
Spring Rate: 720 lbs./in.
O.D. of Outer Spring: 1.677''
I.D. of Outer Spring: 1.203''
I.D. of Middle Spring: 0.874''
I.D. of Inner Spring: 0.632''
Coil Bind height: 1.142''
Weight: 195 grams
Damper Included: No
eBay link to purchase or make offer: https://www.ebay.com/itm/273768713756
Jimmy D is offline   Reply With Quote
