Old 03-23-2019, 09:00 PM   #1
pintojoe II
Default 8” ford rear
8” mustang II housing / axles / 2 complete center sections + extra small parts and 2 sets of gear. Selling as complete lot. Will not separate any thing.
Mustang II housing end cut off and straightened / back brace / S&W wheelie bar mounts / shock relocation brackets.
Center section #1.. 35spline M/W spool / cryoed gear case / cap girdle / aluminum pinion support / Rem finished and cryoed 3:80 gears / all MicroBlue bearings / billet steel yoke..
Center #2 all same as #1 except cryoed only 4:11 gear set.
M/W 35 spline axles / 5-4-1/2 bolt pattern / drilled for 1/2 or 5/8 drive studs.
Complete brake assembly’s / backing plates & drums.
$1200
pintojoe II is offline   Reply With Quote
