Old 03-20-2019, 11:15 AM   #1
dlv4540
Liked 2 Times in 1 Post
Default 1969-70 396-375HP & 427 Parts
1969 #4296 Holley carb restored, recolored & bench tested with a early service date $1500
ZL1 aluminum tall deck can am and yenko block with a 4.40 standard bore $8,000
1969 3919840 heads both dated L-18-8 fresh rebuild $1850
1969 3919840 heads dated J-30-8 & J-31-8 with new hardware to build $1400
1969-70 3964291 heads dated F-6-9 & F-18-9 with hardware to rebuild $1400
1969-70 396 4 bolt block casting 3969854 dated H-20-9 with a CKO code and have pistons, rods, steel crank, harmonic balancer and new oil pan $2500.
3/8 dimple rods $300
Mickey Thompson valve covers $100
Can ship if you cannot pick up and can be reached at 330-770-2517 for any questions or pictures needed.
dlv4540 is offline   Reply With Quote
