Old 03-17-2019, 05:40 PM   #1
grnmnsrt
Default 1972 Pontiac Ventura
455, Stock block
Edelbrock Heads, 72 cc
Stud Girdle
Harland Sharp Rockers
Victor Intake
950 Dominator
Holley regulator
Meziere water pump
Alternator
Aluminum radiator with dual fans
HEI with new MSD wires
MSD 6AL
5” Recall tach
B&M Pro Stick shifter with Line Loc
Headers, 3” Flowmasters
TCI Midplate/Flexplate Shield
New ATI Flexplate
New RobbMc starter
New steering box
TH400 (just rebuilt) Reverse Manual valve body with transbrake
9” Converter
B&M transcooler with thermostatically controlled fan
SS Braided cooler lines
New Interstate battery relocated to trunk
Fuel cell with sending unit in trunk
8 point cage with easy access for driver
New RCI harness, expires 12/20
Narrowed 12 bolt, tubbed, Moser axles, Perfect Launch Aluminum rear end cover
Ladder bars with new heim joints and hardware
Mickey Thompson Sportsman Rears 33-21.5-15, Weld Drag Stars15x15s
Mickey Thompson Sportsman Front runners with Weld Drag Stars
New Afco Double Adjustable Shocks, 150# springs
Nice interior, new door panels, new headliner, new carpet, racing buckets
New hinge pins installed on doors
Body is in very good shape
95% ready for track or drive on the street as is
We just spent $3,000 at Farks Supercars in NJ, with the new shocks/springs, new crossmember, ladder bar hardware, set pinion angle, set ride height, chassis squared, front end aligned
Car is currently in Bronx, NY in a heated garage and can be seen and heard at any time.
$25,000 or best cash offer
grnmnsrt is offline   Reply With Quote
