Old 03-14-2019, 11:42 AM   #1
jsilveus
Default cleaning Out Garage – Super Stock Parts for Sale
• 9” Mark Williams Aluminum Center Pro
Lighten Gear 5:43, 40 Spline $1,100.00
• Ring & Pinion Set Ford 9”, 5.29 Lighten $140.00
• Ring & Pinion Set Ford 9”, 5:43 Lighten $140.00
• GM 12 Bolt 5.38 $75.00
• Crane Roller Lifter Sets, 7-Sets, 80-150 Runs $100.00 each set
• Torque Converters , 7 total $2,000 for all seven
4-7” , 2- with PG Spline -2 Turbo OR
3-8” , 2- with Turbo Spline, 1-PG $350.00 Each
All 5800 or more in 600+ HP+
• Engine Cool Tank- 12V Pump $200.00
• 13” Electrical Fan $30.00
• Biondo RPM -2-Shift $50.00
• 2-Biondo 2” Transbrake Button $75.00 each
• 2-Bindo 4 ½ “ Transbrake Button $50.00 each
• 6 Sets Used Pushrods
(different lengths, 7.700-7.925) $ (ask)
One New Set, 7931 Comp. 8.280 (16) $60.00
• 16V-12V Battery Charger Moroso Power Charger
(No- 74016) $100.00
• Aluminum Light Valve Covers (Tall) LT1 or L-98 $100.00
• Wheels
Weld- Magnum Drag 5” (4” back) 15x14 set $450.00
Weld- Aluminum Star, 4 ½ “ (4” back) 15x12 set $400.00
Weld-Pro Star, 4 ½ “ (1 ¾ “ back) 15x12 set $300.00
• 350 Olds Parts
New Autolite Plugs AR3910, 6 sets $100.00
350 Holley Manifold $150.00
• Scott McClay M-200 Transmission 2.57 Low
With After -Market Bellhousing & Brake $3,500.00
• Gear Sets- 2- 2.41 and 1- 2.24 $150.00 each
• Misc. Clutch Packs, Used Aluminum Drum $ (ask)
• Sheet Metal Manifold, Small Block Chevy
L-98 or LT-1 $1,200.00
Other Misc. !!!!!! ASK!!!!
Motorhome for Sale
2003 Dutch Star by Newmar
40 ft with 3 slides, 350 Cummins Diesel, Sleeps 4, Always kept in Heated Building, One
Owner, 117,500 miles. VERY CLEAN!!!!
$69,000.00
Van Buren, OH Jerry, 419-348-3336
jsilveus is offline   Reply With Quote
