Old 02-21-2019, 02:49 PM   #1
ohiocamarodave
Default Liberty 5 speed, clutch, and Lakewood Bell
5 speed Liberty with 2.98 low. Old style with welded clusters but gears almost new and new sliders. Extra set of gears with 270 low but 4th gear needs lugs repaired.I only put 11 runs on them. Single disc Ram clutch set up by Hyatt Racing with aluminum flywheel. Extra new clutch disc and weight kit. Lakewood steel bell with adjustment cover and block plate out of cert. Health forces me to go to turbo 400. $5500 for everything. NW Ohio.
ohiocamarodave is offline   Reply With Quote
Old 02-25-2019, 09:08 PM   #2
sean1970ss
Liked 10 Times in 6 Posts
Default Re: Liberty 5 speed, clutch, and Lakewood Bell
Waht is the clutch set up for? Any pictures? Thanks
sean1970ss is offline   Reply With Quote
Old 02-26-2019, 08:21 PM   #3
ohiocamarodave
Clutch was set up for 500 HP SBC in 3400 lb car with 5.14 rear end and 29/10/15. 250 lb base. No pics but can get some if you send your email.
