Old 02-20-2019, 03:42 PM   #1
RACER1530
RACER1530's Avatar
Send a message via AIM to RACER1530
Default 2006 mullis 4 link swing arm slip joint
https://www.racingjunk.com/Door-Cars...IP-JOINT-.html
2006 Mullis 4 Link Swing Arm
Low run car
Car sat 4 years
23 1/2 cage 235 wheelbase
16 volt battery
All new black lines with polished ends last winter
Fuel,water,transmission
Bointnott paint inside and outside
House of Kolor paint
Everything chrome or powder coated
Afco Double adjustable shocks
Strange 4.10 lightened pro gear
40 spline gun drilled axles
B&M air shifter
New MSD7AL3
New Weld V Series double bead locks 16 X 16
New Big Bubbas
New Mark Williams brake calipers
New Master cylinder
New stuff has 80 runs
Dedenbear comand center
Auto meter play back tach,water,volts,oil,trans,and vacuum gauges
Biondo starting line control/throttle stop
Head lights
Mezire polished water pump/Goza chrome filler
2 1/4 to 2 3/8 Chrome Dynatech with merge collectors
Professional wiring
Always towed with air bag
Spare aluminum driveshaft
Scoop has K&N insert
Led interior lights and fuel fill and ignition
Chrome duzs buttons
Just spent 4K on rear wheels and tires last winter
Must see in person
18k rolling. Ray 609-330-4086
Fordyce Motorsports
SC 1538 / SC 153R
RACER1530 is offline   Reply With Quote
