Old 09-27-2007, 07:07 AM   #1
RJ
Default 95 LT1 Camaro info
I am building a 95 LT1 Camaro stocker and need some info. I don't see a timing set available with an indexable crank gear, what is everyone using?. What's the easiest way to mount a metric 200 to the crossmember?. Who makes a lightweight driveshaft that will bolt right in with the metric 200 and a 12 bolt?
Thanks
RJ is offline   Reply With Quote
Old 09-27-2007, 10:11 AM   #2
rx dealer
Liked 53 Times in 13 Posts
Default Re: 95 LT1 Camaro info
RJ...for the driveshaft call dyno tech at 248-362-2777 in troy michigan...luke
rx dealer is offline   Reply With Quote
Old 10-01-2007, 09:23 AM   #3
Woodro Josey
Liked 3 Times in 1 Post
RJ, Rollmaster makes the timing set you want. As for the 200, you just need to weld a Tab on your Crossmember for the mount to connect to! Hope this helps!
Woodro Josey 2002 STK
Woodro Josey is offline   Reply With Quote
Old 10-01-2007, 10:33 AM   #4
BRUCE PARSONS
Banned
Hey Woodrow. Hope things are going well. Would you happen to have a part # for the timing chain assembly? Is there a gear available that doesn't drive the waterpump? Let me know on here or e-mail me direct at pmracingengines@aol.com. Thanks in advance, Bruce
BRUCE PARSONS is offline   Reply With Quote
Old 10-01-2007, 03:16 PM   #5
SSDiv6
Bruce, try Rollmaster P/N CS1080.
http://www.sdparts.com/product/SDCS1...TimingSet.aspx
You can get it at a great price from this guy in Ebay.
http://cgi.ebay.com/ebaymotors/SB-Ch...QQcmdZViewItem
Old 10-02-2007, 06:49 PM   #6
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
A double roller chain will hit the front cover up at the cam gear area. A little material removed from the inside of the cover and maybe 2 cover gaskets for a little extra room.
Rich Biebel
S/C 1479
Stock 147R
