Old 01-29-2019, 05:01 PM   #1
rod butcher
Liked 132 Times in 27 Posts
Default 82-92 Camaro Wilwood Disc Brakes F&R
I have for sale a used complete set of Wilwood Pro Series part# 140-11012 front disc brakes for 82-92 Camaro's. Comes will everything needed to install. Pads are 50% Rotors never been cut and run true. These list for $870.79 Sell for $450 plus the ride. Box weighs 38 lbs. from 01803
Also a set of used Wilwood Dynalite rear disc brake kit #140-5771-BD kit complete. Pads are 75 %. This kit uses the 12 bolt special rear axle flange for 3.150" axle bearing. It also has a 2.91" offset from axle to axle flange. Lists for $567 Will sell for $275 plus the ride.
Rod Butcher
617-320-6876
nhrasg105@yahoo.com
rod butcher is offline   Reply With Quote
Old 02-05-2019, 07:48 AM   #2
rod butcher
Default Re: 82-92 Camaro Wilwood Disc Brakes F&R
Front brakes sold. Thanks Classracer.
