Old 01-28-2019, 06:31 AM   #1
dlv4540
Liked 2 Times in 1 Post
Default 1969-70 Square Port Heads & Shortblock 396 L78
3919840 square port heads both dated L-18-8 fresh rebuild $1850
3919840 square port heads dated J-30-8 & J-31-8 with all new springs & valves $1500
3964291 square port heads dated F-6-9 & F-18-9 with newer springs and valves numbered in bags $1500.
1969 3933163 square port aluminum intake with thermostat dated 9-26-68 $450
1970 396 4 bolt block .030 over with CKO code casting number 3969854 dated H-20-9 with pistons, rods, steel crank, harmonic balancer, new oil pan and baffle $2500.
Mickey Thompson valve covers $100 bbc
Can ship if you cannot pick up and can be reached at 330-770-2517 for any questions or pictures needed.
dlv4540 is offline   Reply With Quote
