Old 01-16-2019, 01:56 PM   #1
NHRA3106
Liked 147 Times in 38 Posts
Default (2) TH-350 Transmissions by Arnett
1-TH-350, rollerized, with aluminum drum, SFI Ultra-Bell, Coan reverse pattern trans brake valve body, deep pan, stock 2.52 low gear. This was ran a short time behind a 3600lb Chevelle, no more than 40 runs. 1,800.00
1-TH-350, rollerized, with aluminum drum, aluminum trans pan, stock case, Arnett built reverse manual valve body, 2.75 low gear. Has no more than 75 runs since fresh and ran behind a small block running G/SA. Still in car, 1,100.00
I-B&M Pro Ratchet shifter, with Shifnoid solenoid for reverse pattern, no cable, 375.00
Will ship at buyer expense, possibly meet, or pickup, located in Midway, KY
Kevin Wells
502 316-4667 call or text
NHRA3106 is offline   Reply With Quote
