Old 01-14-2019, 02:31 AM   #1
harry k
harry k's Avatar
Send a message via AIM to harry k
Default Ford C4 Drag RaceTransmission & Art Carr 9" Torque converter
Ford C4 Drag Racing Transmission & Art Carr 9" 5500 + RPM stall anti ballooning plate torque converter
Transmission has PA Performance transbrake, Alto racing rigid band with red eagle clutches and Kolene nitrided steel plates. PTFE teflon rings, Sonnax C ratio purple billet servo, Billet input shaft,6 pinion front planetary, the case has been tapped for overflow
cast aluminum deep pan (magnet attached to it at the bttm of pan) & JW Ultrabell sfi bellhousing for BBF, -6 cooler line fittings
trans and torque converter freshened up and have not been used,ready for the new year race season for you.
local pick up in Van Nuys Ca.91411 818 908-1746
harry k is offline   Reply With Quote
