Old 01-12-2019, 04:09 PM   #1
BTR69
BTR69's Avatar
Liked 90 Times in 27 Posts
Default Tow vehicle
Good afternoon. looking for opinions/input on the 3500 series gas engine trucks. looking in the 2012-2015 year range. Towing a 24' enclosed with 3400# car and other goodies. Had been shopping for diesel, but the gas trucks are about 4-6000 less around here. Also curious about going with single rear wheel. I know the dually is more stable, just curious how much of a difference it makes going to single rear. Currently running a 98 Chevy 3500 dually, but it's getting a bit worn out as my daily driver work truck. Thanks in advance.
William Kilduff
1970 Barracuda (still trailer jail, indefinitely?)
1968 Camaro SS/C
BTR69 is offline   Reply With Quote
Old 01-12-2019, 04:37 PM   #2
RULER
Liked 58 Times in 18 Posts
Default Re: Tow vehicle
Go with a 2001-2007, 8.1 GM there hard to find but very durable. There's no other gas engine that can compare
RULER is offline   Reply With Quote
Old 01-13-2019, 01:22 AM   #3
Larry Merk
Larry Merk's Avatar
Liked 314 Times in 113 Posts
William,
I tow a 24 foot enclosed trailer hauling a 3,000 pound car with all the usual stuff inside. I tow with a Chev 2500 HD with a single rear wheels and it tows like a dream. We have also towed the trailer with my sons Chev 3500 with dual rear wheels. Can't really tell any difference. He bought the dually because he plans to put a camper on the truck and wanted the extra load capacity. Both our trucks are crew cabs with the Duramax / Allison drive train. The dual wheel will certainly be more stable, so buy that if you have any doubts. For me, the single rear wheel setup works fine.
Larry Merk
Larry Merk is offline   Reply With Quote
Old 01-13-2019, 10:22 PM   #4
BTR69
BTR69's Avatar
Thanks for the input guys. Sounds like the 2500 series could be in play as well now. Hadn't totally discounted it, but knowing how much my 1500 struggles with the enclosed empty, I hadn't really considered it much either.
William Kilduff
1968 Camaro SS/C
Old 01-14-2019, 06:32 AM   #5
jmcarter
jmcarter's Avatar
Liked 3,247 Times in 987 Posts
FYI that they are coming out with larger gas motors in the 2020 models. The 6.4 Hemi is a pretty good motor and you can find them a bit cheaper than the competitors.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 01-16-2019, 02:07 PM   #6
BTR69
BTR69's Avatar
Ran across a 2016 Ram 2500, 4 door cab with the 6.4 hemi & automatic trans today. 84,000 miles and looks to be in good shape. Was a coorporate owned truck. Going to see what I can find about tow ratings and such. Any suggestions of what I may want to look out for on it?
William Kilduff
1968 Camaro SS/C
Old 01-16-2019, 02:30 PM   #7
jmcarter
jmcarter's Avatar
I'd call Jeff Teuton...know he's recommended the 6.4 and probably has a wealth of info.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 01-16-2019, 06:03 PM   #8
BTR69
BTR69's Avatar
Thank you sir. Sent Jeff a PM. Have a great week.
William Kilduff
1968 Camaro SS/C
