Old 01-03-2019, 07:14 AM   #1
JeffM
Liked 5 Times in 5 Posts
Default New and used parts/garage sale
Holley Hi Ram LS3/LSA intake manifold PN 300-116 – new in box complete with fuel rails, seals and bolt kit $675.00
Holley fuel rails pn 534-203 new $125.00
2 - 327 Forged Crankshafts std std – will need to be turned - $65.00 ea
Autometer electrical 100psi sending unit with 3ft of -3 braided line – $20 Used
Computech Datamaxx data acquisition main module with harness. $400.00 used
Computech Datamaxx LCD screen $450.00 used
Jegs heater (wraparound style) $20.00
Powerglide transmission with stock case, ATI 1.98 S/S with coan 300m PG input. Stefs pan with heater, TCI brake, freshened by Defiance Transmission (Ken Shawver). Less than 20 passes on the new 1.98 gearset. $1350.00
Coan 350 transmission with brake - removed from car and doesn’t need anything. 2.38, or 2.30 first gear $1500.00
Cometic LS7 head gaskets (New/pr) 4.200 bore .056 PN H2462spb056s $100.00
Cometic LS7 head gaskets (New/pr) 4.200 bore .053 PN H2462spb053s $100.00
Cometic LS7 head gaskets (New/pr) 4.200 bore .060 PN H2462spb060s $100.00
Pac valve spring locators 1.270 x .640 x .520 x .060 PN PAC-S121 (dyno test only) set of 16 - $30.00
Pac valve spring locators 1.270 x .600 x .520 x .060 PN PAC-S128 (new open box) set of 16 - $45.00
Pac valve spring locators 1.270 x .615 x .575 PN PAC-S138 New set of 16 $175.00
Pac Titanium retainers 1.200 x .890 x 600 PN PAC-R532 (dyno test only) set of 16 - $250.00
Pac Titanium retainers 1.200 x .890 x 600 PN PAC-R432 (new open box) set of 16 - $170.00
Pac Tool steel retainers 1.250 x .890 x .600 PN PAC-R632 New set of 16 $260.00
Pac valve spring locks 8mm Mini8 +.050 PN L8142 new set of 16 $55.00
Pac titanium valve spring locks 5/16 Mini8 STD PN L8139 new set of 16 $125.00
Pac titanium valve spring locks 5/16 Mini8 +.050 PN L8123 new set of 16 $125.00
Pac titanium valve spring locks 5/16 Mini8 +.050 PN L8124 new set of 16 $125.00
Pac dual valve springs PN PAC-1237X – (dyno test only) set of 16 $225.00
Pac dual valve springs PN PAC-1238X – (dyno test only) set of 16 $225.00
Pac dual valve springs PN PAC-1335 – (dyno test only) set of 16 $225.00
Pac dual valve springs PN PAC-1335 - new set of 16 $400.00
Callies Compstar 6.100 LS rods with ARP 2000 bolts (dyno test only) $500.00
Callies Compstar 6.100 LS rods with ARP 2000 bolts (used) $350.00
Manley 221443P-16 valve springs with 23648-16 Ti - retainers, locks and 42573-16 locators (run on dyno) $500 for set.
ATI balancer pulley PN 916794 4 groove aluminum 6.430 diameter - New $40.00
ATI balancer pulley PN 916732 4 groove aluminum 6.430 diameter – used $50.00
Meziere WN0032S – 1.50 diam water neck fitting black – $10.00
CV products 3/8 pushrods (qty 18) 9.200 x .080 x 5/16 ends – used but good condition – $30.00
Trend 3/8 pushrods (qty 16) 7.450 x .135 x 5/16 ends – used but good condition) $50
Trend 7/16 tapered pushrods (qty 16) 9.450 x .165 x 5/16 ends new - $100
Trend 7/16 tapered pushrods (qty 16) 9.400 x .165 x 5/16 ends new - $100
Trend 3/8 pushrods (qty 8) 9.400 x .135 x 5/16 ends used - $25
Trend 3/8 pushrods (qty 8) 9.450 x .135 x 5/16 ends used - $25
Comp Cams 3/8 pushrods (qty 16) 7.800 x .080 x 5/16 ends used - $25
Jeff Myers
SS3254
S1522
JeffM is offline   Reply With Quote
Old 01-03-2019, 09:24 PM   #2
jerry witzel
jerry witzel's Avatar
Liked 44 Times in 15 Posts
Default Re: New and used parts/garage sale
Sent you a pm
Old 01-04-2019, 02:26 PM   #3
nickh
nickh's Avatar
Liked 659 Times in 197 Posts
sent you a PM as well.
