Liked 115 Times in 35 Posts
I think this has been discussed before but can you run a single carb in modified? For example if you had a SS/BS car with the 750 carb and wanted to run SS/CM can you run the same 750 carb or any single carb? Or is it 2 carbs only in SS/CM?
