Liked 12 Times in 3 Posts
- 383 SBC engine / every part is brand new never run / aluminum heads / polished / carb to pan - flexplate, water-pump, starter, alternator, distributor, etc. almost $8k invested will make 530-540 hp assembled and ready to fire up. Call for pictures ; $5900
- Book 750/850 ; $800 - Book 850 ; $800 - Connecting rods perfect low run v-8 sets ; $200 set - MSD flying magnet crank trigger system complete SBC used ; $150 - Tons of 3/8” pushrod sets 7.770-9.250 ; $100 set of 16 - Perfect set Jesel .875 lifters for SB-2 drop in ; $600 - 5:28, 5:67, 6:33 - 9” Ford gear sets lightened, coated, cryo’d ; $250 - Mark Williams front brake system / ceramic bearing option. Brackets, Hubs, rotors, calipers, pads. Perfect shape ; $900 - 1 Set new 1.650 titanium valve springs ($1000 new) - $350 - 10 sets used great condition Casidium coated piston pins .866 - .927 many lengths available - $100 set - 15 sets used Titanium valves different lengths and head diameter. Perfect condition - $200 set of 8 - 8 sets used Titanium Victory retainers 10 degree for 1.500 spring size - $100 set of 16 - 10 sets used titanium Victory keepers 10 degree for beadlock valves 5/16 and 7mm - $50 set of 16 - 20 camshafts 50mm, 55mm, clamshell for SBC Wedge, SB-2 and Splayed valve engines. - MSD chips 3000 – 10,600 RPM - $5.00 each - Simpson 5-point harness out of date SFI perfect shape - $100 set - Tons of Racepak parts and accessories (Collars, pickups, transducers, sensors, Cables, etc. Call for pricing WHEELS: - 15 x 10 Alumnastar WELD Wheels, 5 x 4.75 bolt pattern, 5" backspacing, Polished w/ Polished Center ; $800 / set - 15 x 10 Alumnastar WELD Wheels w/ Screw Holes, 5 x 4.75 bolt pattern, 5" backspacing, Polished w/ Polished Center ; $800 / set - 15 x 3.5 Alumnastar 1-Pc WELD Frontrunner Wheels - $1000 / set TIRES: - Hoosiers BIAS 17.0 / 36.0 – 16 #C2055 ; 1 run - $500 - Mickey Thompson BIAS 30.0 / 9.0 - 15 ; 8 runs - $400 - Mickey Thompson Drag Slick 14.5 / 32.0 – 15 #30751 ; 1 run - $450 - Mickey Thompson 32.0 / 14.0R – 15 #11808 ; used - $100 - Mickey Thompson 33.0 / 14.5R – 15 ; used - $100 - Goodyear Radials 30.0 / 9.0 – 15 ; used - $100 - Hoosier Drag Slick 9.0 / 30.0R – 15 #18212 ; NEW - $400 Last edited by Jeff Lane; 12-20-2018 at 11:24 AM. |
Liked 7,985 Times in 1,525 Posts
Interested in 28 inch Hoosier drag fronts .....MJ. 502-49nine-014zero......Thanks...
Liked 3 Times in 1 Post
Interested in MSD chips. Do you have evens, odds or in 100 rpm increments? Sell as a lot? Thanks, Brian
#4 | |
Text me on my cell and I will shoot you over a picture of all the chips I have. They are in an aluminum chip holder. Yes I will sell as a lot. 206-818-1804 |
the 5.28 gears what make are they?
are they new/used ? if used how many runs? they are $250 per set? Jamie Roth text me at 604 785 4458
Jamie Roth 64 Comet,331cuin,Jerico 4sp BC Supershifters |
