Liked 6 Times in 3 Posts
Lowered Price Asking $11,000 or BO
Best ET. 9.45 at 139mph in 3035lbs 1985 Mustang GT 1974 460cid 220hp NHRA rated at 300hp Set NHRA National Record at 1.05 under the index in 2013 D3VE-A2A Cylinder heads done by Jacques Blais Victor intake port matched to heads Wilson spacer to Thermoquad carb Custom Comp roller cam Crower lifters, Jessel rockers, 7/16 double taper pushrods Danny Bee Belt Drive Manley valves, PAC springs Block 460 + .040 partially filled Block has roller cam bearings and bronze lifter bushings Eagle rods with JE pistons ATI damper, MSD crank trigger, MSD billet distributor Custom aluminum Moroso oil pan for Fox body Mustang Custom 3 step headers for Fox body Mustang ATI flex plate, Tilton starter, Meziere water pump, sheet metal valve covers This engine was run this year at the Atco National Open and Maple Grove Points meet. Dyno and Flow sheets available for the buyer Ford 429-460 Parts: 1 set of ported D3VE-A2A heads with matching intake and cam. 1 Block 1/2 filled, .060 over JW Ultra Bell to C-4 trans. cert good to 2022 1 set of Childs & Albert(427-07B) NHRA Accepted Rods 1 set of 429 Ford Cobra Jet rods 1 New Tilton starter Best offer Contact: John 860-918-2524 |
