Old 11-09-2018, 02:05 PM   #1
rod
Liked 20 Times in 15 Posts
Default parts
Holley carbs, complete-need kit. 1850, 6619 & 3310. $20.00 each.
3310 vac, milled choke $50.00
6210 spreadbore $100.00
4778 [700] no choke parts $175.00
4779 [750] no choke parts $175.00
4779 [750] complete as new, new kit, ready to go, $350.00
9" Ford nodular iron N case, bare, $200.00
9" Ford 5.67Schiefer Pro=Gear with a Lenco stem, 1350 companion flange $150.00
9" Ford 5.67 Richmond $75.00
9" Ford 6.20 US Gear [less than 20 easy 1/8 mile runs] $100.00
SBC Flywheel, 30 lb., SFI legal, Long & B&B pattern, new in box $175.00
McLeod SFI Legal 10 1/2" B&B pressure plate, fresh from McLeod with bearing, $150.00
RAM SFI legal 10 1/2" metalic disc, 1 1/8 x 10 $90.00
all 4 clutch parts for $350.00
Zoom 11" disc, 1 1/8x10 new in box, $50.00
Borg-Warner GM T-10 4 speed. 2.20 low. less than 5K street miles. never opened. been under my bench for 42 years!
Hurst Factory 4 speed shifter, free with the T-10.
buy the 4 speed and get the SFI clutch parts for $300.00
Chevy factory cast iron tach drive, single point, window cap dist. $150.00
Mallory YL, 2 set of points & condenser, $25.00
Mallory YC [flat cap] 2 pair [4 total] points and 2 condensers + new rotor $50.00
1954-55 Olds dog dish hub caps, set of 4, $75.00
SBC Blue Racer solid lifter cam with lifters [all new in box] #WG 5053, 272/272 @ 50, .570/.570 105 intake/111 exhaust LC, 108 LSA. $150.00
all parts + ride. will help on heavy pieces.
Rod 928/565-3120 [AZ-MST] call 8AM-8PM]
rod is offline   Reply With Quote
