Old 10-21-2018, 08:44 PM   #1
John Nechiporchik
Liked 13 Times in 7 Posts
Default BBC in Gen 4 Camaro
Need some info on installing a BBC in a gen 4 Camaro.
The car is a Super Stock chassis with modified k- member.
I am trying to determine the best intake and oil pan to run that will provide adequate hood and ground clearance. Likely rectangular port with 850 carb.
The car will have motor plates front and mid.
Thanks for any help on this project.
John Nechiporchik is offline   Reply With Quote
Old 10-21-2018, 09:02 PM   #2
Dragsinger
Liked 99 Times in 60 Posts
Default Re: BBC in Gen 4 Camaro
look for "1320 racer". [Ed Biggley] He has a nice 4th gen like you are planning
Larry Woodfin 471W
Old 10-21-2018, 09:10 PM   #3
John Nechiporchik
Thanks. I sent him a pm earlier today. Saw pics of his car on another site.
Old 10-22-2018, 07:10 AM   #4
nhramnl
Liked 358 Times in 83 Posts
Right in your own backyard, John. Mike Pustelny built at least one of them, for Steve Novosel. He originally built the car Ed Bigley races, but I can't say if it was originally built to be a BBC, or if Ed converted it from a small-block to a big block.
Old 10-22-2018, 08:13 AM   #5
John Nechiporchik
I’ve talked to Mike and he gave me some good tips. I’d like to know what intake and oil pan guys are using that meet the tight dimensional parameters.
Old 10-22-2018, 08:45 AM   #6
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
John, My 4th Gen Firebird was built by MPR, originally as a GT/AA, with a 454 BBC under the hood.
The K member has been modified for both oil pan (Moroso 21049) clearance and custom headers as has been the cowl. Without doing the same to yours, I don't see it happening. Lots more done you don't see.
That said, my engine is not super stock legal and the edelbrock Vic Jr on it has had it's carb pad cut down for hood clearance though I do have a 1" restrictor plate on it.
Old 10-22-2018, 04:05 PM   #7
John Nechiporchik
Ed, Thanks for the information and the photos.
My chassis is modified in a similar fashion as yours with modified crossmember and cowl area. It appears that my rack may be a little further rearward which may restrict lowering the engine in the chassis. Might require modification.
Again, Thanks for your response and helpful info.
The mock up process will continue to see if I can sort this out.
John
