Old 10-11-2018, 11:41 AM   #1
Randall Klein
Liked 316 Times in 67 Posts
Default Help! Need distance eng to hood 69 Camaro
Winter project: 69 Camaro with SS hood in GT class
283 245HP dual 4's
Need to know distance (room) from head ports to hood (w/scoop)
Gonna try a custom small tunnel ram for the dual WCFB's, and I don't want to lower engine
Any help out there
Yes, I could measure but 500CI big block curently in the way and I'm kinda lazy
Thanks in advance
Old 10-11-2018, 12:49 PM   #2
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Default Re: Help! Need distance eng to hood 69 Camaro
Just a shot but maybe measure with the BB in and add the difference between block heights? It would give you a rough estimate. You have to pull the BB eventually, so why not get it over with before Winter sets in? I'm cleaning up my sbf now so I don't have to suffer in the "shop" when it gets nasty.
Dale Shearon
68 Mustang 6394
Old 10-12-2018, 08:33 AM   #3
Alan Nyhus
Liked 799 Times in 236 Posts
Randall, motor plate or traditional frame mounts? I know this doesn't answer all of your question but it's something to take into consideration.
If using the traditional mounts, there are two common sizes. They vary not only in height but width.
If you're going to do the traditional mounts, Elston makes a great mount that allows you to position the engine exactly where you want it.
http://elstonheaders.com/page6.html
"That'll never work....."
Old 10-12-2018, 08:59 AM   #4
nhramnl
Liked 358 Times in 83 Posts
If you've decided that you are (for sure) going to do the project, just pull the BB out and do what the chassis builders do; install a dummy small block with heads and a "mock-up" of the intake you think you're going to use. Sounds like you intend to get carb-to-hood clearance by adjusting the height of the intake and/or carb spacers, because you don't want to lower the engine, and this technique would allow you to achieve that. Also, an interesting engine/chassis combination...
Old 10-12-2018, 09:09 AM   #5
Randall Klein
Just some added info: two potential buyers want to hear BBC run, it also has a fiberglass scooped hood, and I am acquiring the correct factory SS scooped hood; timing issues and logistics prompted me to inquire if anyone had the measurement I need.
I assume this could be from any SS SBC with single 4BBL with intake and carb spacers and how much gap left.
I will be using a motor plate
Thanks for responses
Old 10-14-2018, 10:38 AM   #6
MAURICE BLENDHEIM
Liked 284 Times in 87 Posts
Randall… The idea sounds intriguing and the cowl hood (SS scooped hood you mentioned) would be favourable, obviously. Although, the advantage of the additional height may be impeded by the cowl air filter sealing ring flange. The centre to centre placement of the carburetors will need to be considered, to work with the stock sealing ring flange. With your combination, the carburetor bias will favour the firewall or rear of this flange. In 1969 you could order a Z/28 with dual Carburetors and Crossram intake, but the hood had a different style construction with hood sealing flange that worked specifically for that application. Randall, I haven't answered your question directly, but just didn't know if you were aware of this potential interfering factor. You did mention that you were "kind of lazy" and I didn't want you to construct something that might not work with some of the measurements you may receive. Hope this helps…Maurice.
MAURICE BLENDHEIM is offline   Reply With Quote
