Old 09-19-2007, 08:27 AM   #1
Uncrated
Banned
Default who sells control arm roller bearings
Racers,
do some of you have experience with control arm bearings? Good? Bad? Who builds/sells them?
At this time I have the Global West bushing but I am not sure it is the best setup. It seems to me the "high tech" bushings have too much friction once the suspension is assembled. [they are completely free moving on the bench but I "think" the bushing has too much surface area, causing too much resistance once the suspension is under load]
Thanks for your thoughts and comments
Larry Woodfin
Uncrated is offline   Reply With Quote
Old 09-26-2007, 10:17 PM   #2
theraif
Smile Re: who sells control arm roller bearings
Not sure if this helps or not
http://garysautomotive.net/default.htm
theraif is offline   Reply With Quote
Old 09-27-2007, 10:32 AM   #3
G Schenck
Liked 81 Times in 35 Posts
Default Re: who sells control arm roller bearings
Aurora Bearing Company
603 859-2030
They advertise in back of the National Dragster.
Greg
G Schenck is offline   Reply With Quote
