Liked 994 Times in 200 Posts
Got a 1956 Carter WCFB on my 55 265 Q/SA.The problem is that coming out of the water as soon as you let off of the throttle the car wants to die.You have to stick it in neutral real quick, and bring up the rpms to keep it from dying.It also will also try to quit running when you pull into your pit space,and let off of the throttle.Going testing tonight and I have a fuel pressure gauge on the car now.Will keep a eye on the pressure.Also the oil pump that came with the pan I used has 80 lbs of pressure at 6500 rpms.That seems high to me.
Liked 24 Times in 12 Posts
Is there any black smoke when you try to keep it running? If so, something little in the needle and seat? It doesn't take much.
No black smoke.Seems more like it is running out of fuel.
Does it run down the track fine?
Yes runs fine at WOT.
Liked 316 Times in 67 Posts
May be helpful, maybe not (Grumpy said that to me once!), although we run dual WCFBs, we finally wound up at 14.5 lbs fuel pressure, cured a problem like yours and dying at launch FWIW
Liked 162 Times in 45 Posts
When we ran one of those on our 55 ss car we ran 15-18 pounds of fuel pressure.
For sure going to bump up f pressure.Only has 6.5 now.Had another racer tell me if I want to richen the wcfb up ,just bump up the fuel pressure.Will keep you all informed.Thanks for all the info.Lyn
Liked 333 Times in 180 Posts
U might also want to check float level and make sure that the float is centered in the float bowl not touching the sides of the bowl at all. They were known to do that as well
Liked 13 Times in 6 Posts
Have messed with those old carbs forever. We have run both single and dual in s/s so it is way different- but some things to look at is of course float level and binding,also check floats in hot water for leaks. One of the things carb kits show is to check vacuum passage thru body, fuel will slobber on turns or stops. we have always plugged with a piece of wire. We only run 5 1/2 lbs. for fuel pressure.
Randall-looks like we should try 15 lbs. |
