Old 09-16-2007, 08:46 PM   #1
Chip THELEGEND Johnson
Liked 281 Times in 79 Posts
Default Need help with Holley 750
I have a 4779 Holley on my crate motor stocker.
It worked fine at Darlington and Piedmont. This weekend it developed a hesitation leaving the line. Does'nt hurt E.T. Just reaction time.
I would like to send it off or just buy another carb.
Any suggestions.
Thanks
Chip
Chip THELEGEND Johnson is offline   Reply With Quote
Old 09-16-2007, 09:35 PM   #2
Tim Harris
Smile Re: Need help with Holley 750
Call Billy Plage.He has mine working fine.1.32 60ft
Tim Harris is offline   Reply With Quote
Old 09-16-2007, 10:37 PM   #3
Tim B
Tim B's Avatar
Default Re: Need help with Holley 750
Put bigger squirter's in it.
Tim Blount S/C Q/R 310T
Tim B is offline   Reply With Quote
Old 09-16-2007, 10:55 PM   #4
1347
1347's Avatar
Liked 1,001 Times in 276 Posts
clean out the idle bleeds, they are probably dirty
1347 is offline   Reply With Quote
Old 09-16-2007, 11:33 PM   #5
Mike Hedger
Before you do anything major check if both accl pumps are working. If one is dead pull the squirter and see if the check valve under the squirter is stuck. Take a small pick and move it around to get it unstuck. Be careful not to let it go in the intake it is not magnetic. If it is stuck the accl pump will be very hard to depress with your finger. If it was working/ running OK and now it is not this is most likley your problem. Is it running OK other than the stumble? Hope this helps, Mike
Mike Hedger S/C 4646
MPH Racing and Fabrication
Mike Hedger is offline   Reply With Quote
Old 09-16-2007, 11:34 PM   #6
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Chip easy fix squiter...see what size it has& go up a couple sizes. One other thing..dose it have jet extensions in the secondary? oh almost forgot Cheap fix (or atleast try) rubber hose from the front bowel to the back....it may be dumping fuel from the front into it the carb on take off . make sure to cut a couple small holes in it for air. good luck
Old 09-16-2007, 11:58 PM   #7
Ron Middleton
Liked 12 Times in 4 Posts
Chip,
1. Check idle air bleeds for obstruction
2. Check accelerator pump adjustment and function
3. check pump discharge for obstruction
4. check timing, if timing is still same then go up 1 size on squirter and see if it clears up. If weather is close to prior runs and this did not happen then I suspect timing is off or trash in circuit somewhere. If DA is different then it could be a lean condition and squirter size change should help.
Ron Middleton is offline   Reply With Quote
Old 09-17-2007, 12:14 AM   #8
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Need help with Holley 750
All good advice. But I also believe the air was better this weekend, especially on Sunday.
If your squirters were borderline lean, the air could have leaned them out more. (footbraking)
If you're 2-stepping, it could be borderline lean jetting.
LOCOMOTION Racing
Old 09-17-2007, 07:05 AM   #9
Chris1529
Liked 70 Times in 29 Posts
The idle air bleeds won't cause it to hesitate, it would just sound like a V-6 at idle if they are dirty.
I'd say to go up on the squirters.
Is that the Texas two step you are talking about Myron? If Chip is a little lean doing that, maybe someone should have took him a couple beers! No wonder it took till 300 am to finish that race Saturday!
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 09-17-2007, 07:47 AM   #10
I'm footbraking between 2000 & 2500 rpm's depending on track.
The air saturday was similar to the first 2 tracks.
It is a brand new carb.
Sunday Morning:
We went up on the squirter.
Went up on the timing.
Raised the floats
Adjusted the pump arms.
It did fine the first 3 passes. 3rd rd I dropped rpm to 2200 and it did it again.
HELP ME HELP ME HELP ME.
Chip
