Old 08-18-2018, 09:23 AM   #1
Ed McLawhorn Jr.
Liked 19 Times in 17 Posts
Default Front end limiters
Looking for suggestions on front end limiters for 66 chevy2. I know I could go the chain/cable route from shock tower to upper control arm but was looking for something a little more adjustable. Thanks.
Ed
SS 2266
Ed McLawhorn Jr. is offline   Reply With Quote
Old 08-18-2018, 09:47 AM   #2
Mark Ugrich
Liked 71 Times in 38 Posts
Default Re: Front end limiters
Ed,on my 65 Mustang , which has a similar front suspension, I fabricated a 90 degree bracket from 1/4” steel. Mounted it on the frame rail between the control arms and added an adjustable threaded bumper. The upper control arm will need a 3/16 or so bump pad welded behind the ball joint on the underside of the arm. Keep in mind the control arm is not level and you will need to match the angle. It’s simple and easy to adjust.
