Liked 99 Times in 60 Posts
Some MSD coils are packaged with a ground wire that jumps around the rubber mounts to ground the coil body. What is the function of that ground wire?
Larry Woodfin 471W |
Liked 336 Times in 183 Posts
Larry. It's an insurance wire to make sure you have the coil properly grounded thru the isolation mounts also helps eliminate tach signal issues--- Dick
