Old 08-07-2018, 04:41 PM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default MSD polarity tech question
In recent years the MSD trigger polarity has received some attention. In the "olden days," it was never considered.
For this question, we are talking about an analog MSD 6AL control.
I do understand that for the analog controller, the most retarded timing is the correct polarity. Since the subject began getting attention I have checked a number of 6AL and 7AL analog controllers and so far, each had the correct polarity when the wires connected "color to color" [green to green, purple to purple]
When the colors are swapped, [green to purple] the timing advances about 5 degrees.
Now the question;
Why does the wrong polarity advance the timing? It is as if the controller is predicting the future
Does the control box, when polarity is correct, have that much signal delay? [about 5 degrees]
Anyone know the truth?
Larry Woodfin 471W
Old 08-07-2018, 05:45 PM   #2
FED 387
Liked 333 Times in 180 Posts
Default Re: MSD polarity tech question
Larry sent u an email. Dick
Old 08-08-2018, 07:51 AM   #3
Dragsinger
the signal is either triggered at the leading edge of the wheel magnet [incorrect polarity] or the trailing edge of the wheel magnet, [correct polarity] thus, the difference in timing.
The analog controller is designed to process the trailing edge signal.
Larry Woodfin 471W
Old 08-12-2018, 10:01 AM   #4
Adger Smith
Liked 880 Times in 311 Posts
Larry, Do you have a scope?
Adger Smith (Former SS)
