Old 07-27-2018, 01:13 PM   #1
Jack McCarthy
Liked 477 Times in 117 Posts
Question DOT info help
id love someone to help me understand the DOT rules as i have an opportunity to tow a vehicle to/from exhibitions for a group. Simple dually and tagalong 26ft trailer total weight under 22,000 probably less.
Will be across the USA have bookings in NY, Nevada,La,Va already for 2019
ive read the HORROR stories from you guys so i would like to be informed as best as possible !!
thank you in advance for your help !!
captain
Jack McCarthy 3609 STK
"the Captain"
Jack McCarthy is offline   Reply With Quote
Old 07-27-2018, 02:03 PM   #2
Philip Saran
Liked 14 Times in 11 Posts
Default Re: DOT info help
Deleted
Phil Saran
Parker, Colorado
Philip Saran is offline   Reply With Quote
Old 07-27-2018, 02:10 PM   #3
Dave Crysler
You may need to have a log book, if you want pm your phone # and I will try to explain.
Dave Crysler is offline   Reply With Quote
Old 07-27-2018, 05:17 PM   #4
Painter
Liked 162 Times in 45 Posts
Jack, call me, I have been thru all of this. Jeff helped me out, and I THINK that I have the answers. But when you run into Buford T on the side of the road there is nothing that will help until you get to court.
Painter is offline   Reply With Quote
Old 07-28-2018, 01:18 AM   #5
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
If the GVWR of the trailer is over 10,000 lbs, you technically need a Class A although on a 26' tandem axle I doubt you would be hassled.
Signage on the trailer will also be likely to garner more attention.
S/ST 51
S/C 53
Old 07-29-2018, 07:31 PM   #6
MR DERBY CITY
Liked 8,021 Times in 1,526 Posts
Captain, if either the GVWR of the dually or the trailer is over 10,000 lbs. you will need a CDL...you are hauling a vehicle up and down the highway and you are being compensated ....ie ....you are being paid to transport this vehicle....a vehicle that is not titled in your name.....As Painter pointed out, when Buford T Justice pulls you over the **** will hit the fan. After you play dumb and tell him you didn’t think that you needed a CDL you will need a FOLDER to put all the tickets in...He will park you until you locate a local driver with a CDL to drive your rig to the state line...Now, with all that being said....when you open the trailer door to show Buford T what you are hauling, there is the possibility he may drop to his knees and roll on the ground laughing his Azz off.......
Old 07-29-2018, 07:41 PM   #7
JHeath
JHeath's Avatar
Liked 370 Times in 101 Posts
Has anyone ever weighed a 26' trailer ?
Jerry Heath
I/S '93 Cobra
FS/J 2010 Mustang "Ebay CJ"
Old 07-29-2018, 08:30 PM   #8
voltdr
Liked 100 Times in 51 Posts
It doesn't matter what it weighs, unless you reclassify it. The GVW is what they look at. The fact that you are being compensated for transporting this vehicle to and from events makes you commercial and all the rules apply. Log Book, or ELD, US DOT numbers, physical, drug card. same as OTR drivers. Limited driving time.............................................. .................................................. ....................
Dan
Dan Foley
SC 4698
voltdr is offline   Reply With Quote
Old 07-30-2018, 05:08 PM   #9
J&S Racing
Liked 319 Times in 82 Posts
A CDL is required to drive any of the following vehicles: Any combination of vehicles with a gross combined weight rating (GCWR) of 26,001 or more pounds, providing the gross vehicle weight rating (GVWR) of the vehicle being towed is in excess of 10,000 pounds.
If truck and trailer weigh 10,001+ a DOT # is required.
I'm not sure at what point you need a log book but if you do....... a ELD must be used unless the engine is 99 or older. There is also the short haul exemption. If you travel 100 air miles and return home every night no log needed. Then that has the rolling 30 exemption, this states you can travel outside the 100mi 8 days out of every 30 working days. Now I've asked 3 DOT officers if you can stay out on these 8 days but received 3 different answers.
There's also a motor sport exemption. Lol
My advice, do everything not to get stopped. Biggest thing I see guys getting pulled over for is traveling I'n the truck restricted lanes. This is even if your towing a open trailer. If you do get stopped, don't ever give DOT attitude!!! They will ruin your day quick!!
Old 07-30-2018, 08:25 PM   #10
63corvette
Liked 359 Times in 103 Posts
[QUOTE=J&S Racing;568727]A CDL is required to drive any of the following vehicles: Any combination of vehicles with a gross combined weight rating (GCWR) of 26,001 or more pounds, providing the gross vehicle weight rating (GVWR) of the vehicle being towed is in excess of 10,000 pounds.
Not totally true.
If the vehicle is a personal vehicle titled in your name and registered RV and you own the entire contents personally you only need a class A or B depending on the vehicle being towed. Under 10,000 lbs Class B over 10,000 class A.
Called a Non Commercial CDL with no log book etc.
What I currently have.
My 2 Cents
Rick in TX
63corvette is offline   Reply With Quote
