Old 07-24-2018, 08:16 PM   #1
NHRA1285
Default 1973 Dart 340 H & G/S
1973 dodge Dart Sport, Actually a 71 Plymouth Duster 340, Dart Sport sheet metal done in the mid 70’s
Engine: 340 +.060 over, Steel +.013 crank, Eagle rods, JE pistons, Luneack ring package, Filled passenger
car block, 587 heads done by Don Studley, Comp springs, SSI valves, Engle rockers, Smith push rods,
Comp Cam 268-272’, Shubeck lifters, Stahl headers, Trans ect, Jerico 3.19 low, Liberty shifter
Advanced clutch, could use freshening, Lakewood bell, Moly driveshaft, Dana 60 w/ 5.13 gears
Cal Tracs w/ split monos, Rancho shocks, Weld wheels, Hoosier drive tires. M/T fronts,
Drum brakes all around, Loose front end, Koni shocks, Msd ignition w/ two step, Autometer gauges
Car 60’s great, Lots of little tricks done that ad up to an efficient race car, No doubt a blast to drive.
Offered at 13,000. You can’t buy the parts for this car for that.
E mail: hek@supercarrestorations.com or call 716-498-6672 after 7pm eastern time. If truly interested.
NHRA1285 is offline   Reply With Quote
Old 08-03-2018, 10:21 PM   #2
Rod Greene
Liked 242 Times in 81 Posts
Default Re: 1973 Dart 340 H & G/S
Mild steel roll bar or cage? When was last time it was run? ET? Are there pics I looked on autoimagery but couldn't find any? Advance clutches single 10" or 7" Dual? How light will it go?
Thanks, Rod
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects.
Rod Greene is offline   Reply With Quote
Old 08-05-2018, 12:51 PM   #3
Demon340
Liked 108 Times in 29 Posts
Rod, I am not sure if you can go back on Racin Junk? the car was for sale with pictures, I think about a year ago. At the time the owner posted that it needed updated and has been sitting, if I remember right, since 2009ish.
Larry
Demon340 is offline   Reply With Quote
