Old 07-13-2018, 10:29 PM   #1
cal
cal's Avatar
Liked 31 Times in 18 Posts
Send a message via AIM to cal
Default Strange Oil Pressure Problem
Hello All
I have a strange oil pressure problem. First I must tell you this is a 327/295 combo, that came in a car that I bought. The Motor was originally done by Jeff Stealey. The only thing I changed on the motor was the oil pan. The Oil used is 10/30 Brad Penn.
When the motor was started up it had 55 to 60 LBS oil pressure.
Once the motor reached operating temp around 160/170 degrees, the oil pressure started dropping down to 20/25 LBS of pressure. even if you rev it up, it would only go up about 5 LBS then fall right back down. (this happened while the motor was idling at 1300 RPM)
Cutting the motor off for a few minutes and starting it back up, the oil pressure would again be at 55 to 60 LBS. Once it would run for a few minutes it would drop down again to 20/25 LBS.
I say ok need to replace the oil pump, so that what we did. Guess what it did the same exact thing.
Slightly confused, any ideas?
Would it help if I put 20/50 oil in it?
O yea it never totally lost oil pressure.
Thanks for any ideas or explaintion
Cal
cal is offline   Reply With Quote
