Old 09-13-2007, 06:43 PM   #1
Brett Brown
Liked 5 Times in 2 Posts
Question 82-92 Camaro Rear Shock & Spring?
What rear shock & spring are most people using on an 82-92 Camaro Stock eliminator car?
Thanks
Brett Brown is offline   Reply With Quote
Old 09-13-2007, 07:05 PM   #2
Matt S
Liked 20 Times in 12 Posts
Default Re: 82-92 Camaro Rear Shock & Spring?
Interested here as well..
Matt S is offline   Reply With Quote
Old 09-13-2007, 09:49 PM   #3
REGGIE WINKLES
Liked 39 Times in 9 Posts
Brett, I use the stock 84 Z-28 springs with Air Lift bags @ 6 p.s.i. in left and 10 p.s.i. in
right. Hal Stocker Star shocks (setting #3). My car is a stick and weighs 3295 with me
onboard. I use an Alf Weibe torque arm set-up, stock Z-28 stabilizer bar and no traction
bars. Remember, each car is different along with driving styles. Hope this will get you in the ballpark.
p.s. You will need nylon bushings on control arms and panhard bar.
Reggie Winkles
4102 J/Stick
REGGIE WINKLES is offline   Reply With Quote
Old 09-19-2007, 01:46 AM   #4
Brett Brown
Anyone else care to share what they use?
Old 09-19-2007, 08:53 AM   #5
MYLINRACING
MYLINRACING's Avatar
I run a 86 trans am, i run the factory rear springs and lakewood 50-50 shocks, with a adjustable jeg's torge arm, i plan on changing the rear to adjustable afco or hal shocks over the winter. Just have to try different stuff to see what will work for your combo.
Andy Mylin
9441 s/gtb
MYLINRACING is offline   Reply With Quote
Old 09-21-2007, 11:16 AM   #6
Tommy Gaynor
Tommy Gaynor's Avatar
Liked 5 Times in 3 Posts
Brett give me a call
Tommy Gaynor is offline   Reply With Quote
Old 09-21-2007, 05:55 PM   #7
Lambertcars
I Have A 91 Firebird That Has A 330 Hp Vortec That Runs Ihra F-crate Motor Stock .i Have The Stock Rear Springs With The Rubber Pad On Top Of The Spring.i Have A S&w Torque Arm And A Lakewood Panhard Bar.i Tried This Setup With The Air Bags And The Car Twisted Very Bad And Was Inconsistent On The Launch. I Then Removed The Air Bags And Installed A Set Of Joe Russell Adjustable Traction Bars And That Took Care Of The Twist And Inconsistency On The Launch. I Ran This Past Weekend At Carolina Drag Ways Ihra Meet And My 60 Ft Was 1.37 And My Time Was 6.78. I Would Not Even Consider Racing My Car Without The Joe Russell Bars. I Forgot To Mention The Rear Shocks Are 50-50 Lakewood. Hope This Helps.
Allen Lambert
Lambertcars is offline   Reply With Quote
