Old 07-05-2018, 12:00 PM   #1
Chipper Chapman
Chipper Chapman's Avatar
Liked 166 Times in 71 Posts
Default 1971 Chevelle D-E-F/SA
We have decided to sell our 1971 Chevelle Stocker. Car is actually a 1970 changed to 71, still have the 70 parts to go with. The car was built about 3 years ago, good solid car to start racing with or add second car to your team. It runs the low compression 454 LS5 combo, factory rated at 360, 355 by NHRA, TH350 with 2,52 low, some factory lightweight stuff but nothing special, ATI valve body, PTC 8" converter, Engine has cast crank that was offset .014", eagle h beam rods, venolia pistons, Total seal normal race rings, Heads are casting 820, have ferrea valves, comp springs, Bullet cam, solid lifters, Aeromotive fuel pump. 12 bolt rear with strange axles spool and 4.33's. Monocoque wheels, Wilwood front discs. Car is a basic car but a very good solid car. Goes 11.0's@119 in D/SA, running about 50# heavy and with 15w40. Lots left in this combo but dad is ready to hangup the driving suit. We are asking $18500 CDN whic is only $14,000 USD right now. Located in Nova Scotia Canada. Call Chris at 902-956-1962, Can email or text some pictures.
Chris Chapman
1969 Chevelle
NHRA F-G/SA 1090
Old 07-05-2018, 06:23 PM   #2
Chipper Chapman
Default Re: 1971 Chevelle D-E-F/SA
Originally Posted by chipper chapman View Post
we have decided to sell our 1971 chevelle stocker. Car is actually a 1970 changed to 71, still have the 70 parts to go with. The car was built about 3 years ago, good solid car to start racing with or add second car to your team. It runs the low compression 454 ls5 combo, factory rated at 360, 355 by nhra, th350 with 2,52 low, some factory lightweight stuff but nothing special, ati valve body, ptc 8" converter, engine has cast crank that was offset .014", eagle h beam rods, venolia pistons, total seal normal race rings, heads are casting 820, have ferrea valves, comp springs, bullet cam, solid lifters, aeromotive fuel pump. 12 bolt rear with strange axles spool and 4.33's. Monocoque wheels, wilwood front discs. Car is a basic car but a very good solid car. Goes 11.0's@119 in d/sa, running about 50# heavy and with 15w40. Lots left in this combo but dad is ready to hangup the driving suit. We are asking $18500 cdn whic is only $14,000 usd right now. Located in nova scotia canada. Call chris at 902-956-1962, can email or text some pictures.
no longer available, thanks to all who called!
Chris Chapman
1969 Chevelle
NHRA F-G/SA 1090
