Liked 10,813 Times in 2,247 Posts
Yamaha EF6600DE electric start generator (gas) with exhaust stack. Generator will power trailer and one A/C in motor home
16' 6000# Gemini Lift with catch can and safety pins top and bottom. 11'3''inside height, tall enough for '86 C10 race truck on top and chase car on bottom and golf cart with top, on floor under 8' storage deck. Height under storage deck 6' 4'' Aluminium floor with hold downs I have Haulmark prints to show floor plan and cabinet size and spacing. Fresh brakes, 12/15/2017, on all three axles. 17.5 Alcoa wheels with load range "G" tires with spare Alcoa wheel and tire Two AGM group 31 battery's with charger with 50 amp disconnect. 12 volt and 110 volt lights on inside and two outside 110 volt flood lights. Pit Pal stuff, Radio, Superwinch. Model # FPLT85X30WR5 Serial # 16HGB30327H150599 Easy to race out of. Trailer tracks straight behind motorhome Can be seen at most National Events. We will be in Bristol 6/14-17/2018 $30,000 Larry Hill 2 seven 0 - 99four - 400four or PM me |
Liked 37 Times in 33 Posts
Larry,
Will you be at the up coming Indy Divisional July 6-8? Thanks...... |
I had not planed on Indy pts. race, but plans can be changed. Let me know what you have in mind.
Larry,
Sent you a message.. Thanks. |
