Old 06-07-2018, 08:22 AM   #1
Chuck Beach
Chuck Beach's Avatar
Liked 58 Times in 13 Posts
Send a message via AIM to Chuck Beach
Default MOPAR 8 3/4 rear end Summer sale
Mopar 8 3/4 housing - all work done by Moser
Fits A-Body
spring perches are 43" on center (stock location)
spring perches are boxed for added support
fully braced
powder coated
30 spline Moser axles
axles will accept 5/8 screw in studs or 9/16 press in studs
1 pair of 4 degree wedges
1 pair of u-joint straps for aluminum yoke
Center section #1
742 case
4:86 gears
aluminum yoke - for 7260 u joint
Moser 30 spline spool
$700.00
Center section #2
742 case
4:86 pro gear
cryoed & rem finished
$900.00
Center section #3
742 case
5:13 gear
$700.00
Center section #4
742 case
5:13 gear
$900.00
Center section #5
741 case
3:23 gears
posi
7290 yoke
$500.00
Complete rear end with center section #1 - $1500.00 + shipping
Complete rear end with center section #2 - $1700.00 + shipping
Complete rear end with center section #3 - $1500.00 + shipping
Complete rear end with center section #4 - $1700.00 + shipping
Racepak magnetic driveshaft collar (8 magnets) $50.00 + shipping
I have spaces (.110 thick) that go under the yoke so you can use the driveshaft collar with the aluminum yokes $20.00 each + shipping
Strange 3" chrome moly driveshaft - $175.00 + shipping
48 1/2" center u-joint to center u-joint
904 slip yoke - 1310's
1310 to 7260 u-joint
spare 1310 to 7260 u-joint - $20.00 + shipping
742 case pinion seals - 5 available - $25.00 each + shipping
2 - Jaz 3rd member cases - $30.00 each + shipping
5 - stock rear end yokes (10 spline) - 7260 - $25.00 each + shipping
1 - stock rear end yoke (10 spline) - 7290 - $25.00 + shipping
I will be at the Indy divisional and the US Nationals, can bring any of the items above.
Chuck Beach
beachboy3340@aol.com
(740) 833-6507 - mobile
(740) 369-3338 - home
Please leave message
Chuck Beach
3340 STK
Chuck Beach is offline   Reply With Quote
