Old 05-19-2018, 11:22 AM   #1
Mike Graham
Liked 341 Times in 67 Posts
Default Onan diesel help in Bowling Green
Our onan 12k diesel has decided to surge rpm. It changes rpm enough that the output voltage varies about 8 volts. Any suggestions of what to look for or someone in Bowling Green area that can work on it?
Mike Graham is offline   Reply With Quote
Old 05-24-2018, 03:20 PM   #2
Speer Drag Racing
Liked 56 Times in 10 Posts
Default Re: Onan diesel help in Bowling Green
We had this same problem. Ours ended up being a bad bearing on the shaft of the rotor which was wearing on the stator. Had to replace both rotor and stator. Not saying this is your problem but this is what we found. Any luck on getting it fixed?
Speer Drag Racing is offline   Reply With Quote
