Old 04-11-2018, 10:59 AM   #1
dlv4540
Liked 2 Times in 1 Post
Default 1969 M22 & 1973 M21 & Bellhousings
1969 M22 Muncie 4 speed transmission all gone through with new bearings and synchronizers. The tranny has the original GM gears in it along with the correct #660 main case, #306 side cover and #584 tail shaft with no vin stamping $2500.
1973 M21 Muncie 4 speed transmission all gone through with new bearings and synchronizers. The tranny also still has the original GM gears along with the correct #661 main case, #648 side cover #764 tail shaft and is stamped 13K574866 P3E05B $1000.
Big block factory aluminum bell housing #621 cleaned and painted dark charcoal gray $275.
Small block factory aluminum bell housing cleaned and painted rally green $200.
I can be reached at 330-770-2517 for pictures or any questions and can ship if you cannot pick up.
dlv4540 is offline   Reply With Quote
