Old 04-02-2018, 08:02 PM   #1
R5ROB
R5ROB's Avatar
Default Modified super stock
With a 398 ci motor what would the weight be base off of for that ci and index ( class ) for modified super stock in a fwd conversion car ?
R5ROB is offline   Reply With Quote
Old 04-02-2018, 09:03 PM   #2
CDodd4615
Default Re: Modified super stock
SS/AM-7.50 lbs per ci Index-9.00
SS/BM-8.50 lbs per ci Index-9.20
AM-2,985lbs 2,836lbs with an automatic transmission
BM-3,383lbs 3,214lbs with an automatic transmission
Christopher Dodd
4615 GT/EA
CDodd4615 is offline   Reply With Quote
Old 04-02-2018, 09:21 PM   #3
Hacksaw
Liked 311 Times in 175 Posts
SS/AS 3380 lbs @ 9.60 index. SS/AM 2985 lbs @ 9.00 index , minus 5% if you use auto trans, either class.
Old 04-03-2018, 05:54 AM   #4
R5ROB
R5ROB's Avatar
Thanks guys
Forced to put scoop on car with combo
Old 04-03-2018, 09:52 AM   #5
340Cuda
Liked 805 Times in 341 Posts
R5Rob:
Looking at your screen name is this going to be an R5P7 engine?
Thanks,
Bill
Old 04-03-2018, 03:16 PM   #6
R5ROB
R5ROB's Avatar
Sold all my R5 stuff
Gen 3 Hemi going in my avenger
Old 04-04-2018, 08:40 AM   #7
cutta
cutta's Avatar
Liked 5 Times in 2 Posts
Sounds like an awesome build. Are you using one of the new aluminum G3 blocks? and what rocker arm system did you end up going with?
Adriel Paradise, Paradise Racing Team
Driver/Crew Chief(at least my dad claims me to be)
B.S. Mechanical Engineering, University of Arkansas
cutta is offline   Reply With Quote
Old 04-04-2018, 12:32 PM   #8
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
In Modified Stock section 12D (one four barrel) a Hemi can only run in AS.
In Modified section 12F (two four barrel) a Hemi can run in AM or BM.
There are cylinder head restrictions for each each class, read the rule book with care.
Dale Shearon
68 Mustang 6394
Old 04-04-2018, 06:42 PM   #9
R5ROB
R5ROB's Avatar
AS single carb is limited to cfm
Plan on to run AM with no restrictions on carb or dual carbs allowed
Mine is setup with single billet 2.400
Old 04-04-2018, 08:24 PM   #10
Hacksaw
No on the billet carb. But ... check out Scott Gove's Avenger, SS/AM 7.90's car really rocks!
