Old 03-30-2018, 09:02 AM   #1
Steve Stickel
Steve Stickel's Avatar
Liked 50 Times in 23 Posts
Default FORD CP custom pistons for N351 Sportsman heads
New CP custom pistons, for N351 Sportsman heads
4.080 bore Flat Tops
Lateral Gas ports
.043, .043, 3mm ring package
1.325 Compression height .927 pins
Complete Package includes wrist pins and ring set
All New in Original box. $550 shipped paypal ok
New In Box CP custom pistons for N351 Sportsman heads
4.045 bore Flat Top Pistons
Lateral Gas Ports
.043, .043, 3mm ring grooves
1.250 compression height
.927 wrist pins included
ring set not included
$400 Shipped paypal OK
PM For Photos
Steve Stickel
1161 Stk
1167 SS
Steve Stickel is offline   Reply With Quote
Old 03-30-2018, 12:06 PM   #2
Larry Ingram
Default Re: FORD CP custom pistons for N351 Sportsman heads
Steve; what rod, stroke combo were you working with on the 4.045, 1.250 set of pistons? Thanks Much Larry
Larry Ingram is offline   Reply With Quote
Old 03-31-2018, 01:09 PM   #3
Steve Stickel
Larry,
You can create 10 12 combos with the 1.250 CH . 8.2 or 9.5 block, from a 308 to a Big Inch 351 (408)Stroker.. These pistons were popular in circle track.
however, customers plan was 3.25 stroke, 8.2 block, Rod Length / 5.315 in. = 335 cu in
PM for more details
Hope this helps,
Steve Stickel
1161 Stk
1167 SS
