Old 03-27-2018, 06:51 PM   #1
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
Default Dana 60 Yoke
This yoke for a Dana 60 was brought to me with a pile of parts. I have not ever seen one like it but my experience with Danas is limited. If you are familiar with it, will it be durable enough for a 3000 lb car running 10.0 with a transbrake on 10.5 tires? If not, what would be an affordable (cheap) replacement that will work?
Old 03-28-2018, 10:04 AM   #2
John Dinkel
Liked 263 Times in 68 Posts
Default Re: Dana 60 Yoke
Looks like the u-joint is held in with 1/4 in bolts. Not sure if is strong enough. What size are the u-joints? You will probably need 1350 joints to be safe. Don't know about cheap.
John Dinkel 3295 STK
John Dinkel is offline   Reply With Quote
Old 03-28-2018, 11:40 AM   #3
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
I can't read the casting number in the second picture, Dwight, but if it's a Spicer yoke you should be able to identify it at the Dana-Spicer (http://www2.dana.com/expertforms/departid.aspx) website. It looks like a cast piece anyway, and I agree with John, you'd be better off using a forged yoke that utilizes u-bolts instead of capscrews and straps. The Moser catalog would be a good place to start.
Lew
Lew Silverman #2070
"The Wagon Master" N/SA
Old 03-28-2018, 12:07 PM   #4
Alan Nyhus
Liked 799 Times in 236 Posts
Dwight, that style yoke was used on many of the 3/4 ton Dodge trucks with the 60 series rear ends, FWIW. -Al
"That'll never work....."
Old 03-28-2018, 05:12 PM   #5
Dyno
Dyno's Avatar
Liked 693 Times in 205 Posts
I broke one just like that 30 years ago in a 10.90 bracket car. Really fudged a lot of stuff up. Use one with U bolts. Dyno
Old 03-29-2018, 08:53 AM   #6
Rsmith38
Liked 28 Times in 15 Posts
Dana makes a yoke that uses U-bolts - looks same as my Dana 44 yoke.
Rsmith38 is offline   Reply With Quote
Old 04-02-2018, 05:48 PM   #7
Wild Wild West
You can also get the Moroso saddles to hold the u-joint in the yoke. Very neat product that works better than regular u-bolts. If you are going to use the 1310 u-joints (like me), make sure that you get the solid ones with no grease fitting. They are considered "heavy duty" or "racing duty" u-joints.
Wild Wild West is offline   Reply With Quote
Old 04-03-2018, 11:39 AM   #8
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Dana 60 Yoke
Best yokes that I've found are billet steel units with u-bolts. They run somewhere between $125 - $200 from some Mopar and driveline vendors. As mentioned, solid u-joints (I prefer Spicer) are another stronger link in the driveline chain.
LOCOMOTION Racing
