Old 03-26-2018, 09:10 PM   #1
Mopar 340
Liked 6 Times in 4 Posts
Default MSD ignition
Just put new msd ignition and msd distributor on my car, and at idle the rpm jumps around about 300 rpm. Timing is set at 36 degrees and I have 1 blue spring and 1 light silver spring in distributor with a blue bushing. Any suggestions on getting it to idle without jumping up and down?
Mopar 340 is offline   Reply With Quote
Old 03-27-2018, 04:46 AM   #2
GTX JOHN
Liked 2,487 Times in 698 Posts
Default Re: MSD ignition
We run both light silver springs if we do not lock out the distributor.
Simple job to rotate distributor on shaft to lock it. If that fixes it it
is probably advance springs......Drag cars often work fine with it locked
even without starting retard.
John Irving
741 Stock
741 Super Stock
Old 03-27-2018, 08:17 AM   #3
pmrphil
Liked 348 Times in 152 Posts
I'd suggest that you verify with a timing light that a timing variation is the cause of your idle changing - if it is, just change to a bit stiffer spring.
Phil Molski
PMR Performance
S/C 1623
Old 03-31-2018, 08:35 PM   #4
Rod Greene
Liked 242 Times in 81 Posts
Like John said lock it out and forget about it.
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects.
Rod Greene is offline   Reply With Quote
Old 03-31-2018, 10:21 PM   #5
Kenny Bomar
Liked 425 Times in 51 Posts
I've seen a bad plug wire make the timing jump around on a locked out distributor u mite check them
Kenny Bomar is offline   Reply With Quote
