Old 03-23-2018, 03:17 PM   #1
Jeff Stout
Liked 704 Times in 281 Posts
Default One way valve at collector for evacuation system
Looking for part number for the valve that screws onto collector and house from valve cover slips on. NAPA says $50.00 each and I walked out. Thanks in advance for part number or year and make of vehicle.
Old 03-23-2018, 03:34 PM   #2
Starship
Liked 12 Times in 1 Post
Default Re: One way valve at collector for evacuation system
Standard Motor Products AV7
Starship is offline   Reply With Quote
Old 03-23-2018, 03:50 PM   #3
Jeff Stout
Thanks I wanted them today or I would order from speed shop. Now if auto parts store has them I'm golden thank you again
Old 03-23-2018, 03:51 PM   #4
1720
1720's Avatar
Liked 2 Times in 1 Post
Moroso Replacement Check Valves 97800?
https://www.summitracing.com/int/par...illocation=int
RT - SS/X circa 1972.
Talbot Racing Family
1720 is offline   Reply With Quote
Old 03-23-2018, 06:07 PM   #5
FED 387
Liked 333 Times in 180 Posts
u need a Dorman 355050 --- its called a secondary air injection check valve about $12-15 - most auto parts stores--go to a late model junk yard look for most any 92-2007 or so GM car they go and are part of the plumbing for the pollution stuff should be by the exhaust manifold-- remember that GM used the type the had Hose barbs on both ends an the type that had a hose barb on one end and a female threaded port on the other end ---FED 387
Old 03-23-2018, 06:42 PM   #6
TERMITE S/G 2122
Liked 9 Times in 6 Posts
Autozone cv8 By BWD
TERMITE S/G 2122 is offline   Reply With Quote
Old 03-23-2018, 06:55 PM   #7
CMcAllister
Liked 920 Times in 259 Posts
NAPA is a Echlin CRB 229000 $16-18.
Old 03-23-2018, 06:58 PM   #8
FED 387
Actually if u find the right parts store $6-8
Old 03-24-2018, 09:14 AM   #9
MAURICE BLENDHEIM
Liked 284 Times in 87 Posts
What we have found with these common check valves is, they require more vacuum and more crankcase pressure to move internal valve off the seat. In their original form they are designed to stop exhaust back pressure from entering air injection system. An air injection system develops a higher pressure than what your crankcase pressure "should not be". The header vacuum signal also is in most cases is not high enough to move valve off the seat either and back pressure in an open header application has as close to zero back pressure as you can get. These check valves actually work when you hollow them out with a drill. Your crankcase pressure is then evacuated through those relatively restricted breathers in the rocker covers, through the 3+ foot long 5/8" hose connected to the check valves that are mounted to the 1/2" NPT nipples that are 3-4" long that has one end cut on a 45 degree angle with an orifice cut into it, scientifically positioned into the collector that develops a very "low to no" vacuum signal, to create an evacuation atmosphere or a complex "road draft" system. Check it out and see what I mean. I stand to be corrected. Maurice.
MAURICE BLENDHEIM is offline   Reply With Quote
Old 03-24-2018, 09:23 AM   #10
MR DERBY CITY
Liked 8,014 Times in 1,526 Posts
Jeff, I know you have multiple race cars ...you do realize you can not run a vac u pan system in stock eliminator .?
