Liked 203 Times in 52 Posts
Super Stock 454 Engine
- 454 +.060 over 8.5 Compression - NHRA rated at 341 HP - Studded 2 bolt block that is partially filled. - Bushed lifter Bores - Calico coated bearings - Custom Comp Cams Roller - Crower Lifters - GM Steal crank - Eagle steal rods - C/P 3 ring pistons and pins - ATI Dampener - Custom Steal Oil pan - Cylinder heads are 236 casting with welded D port exhaust - Ferrea Valves and Manley springs - T/D 1.7 rocker assembly - Composite valve covers - Matching ported intake - Q-Jet carb - Wilson Spacer - MSD Billet distributor. This engine is fresh and ready to go. Complete carb to pan , flex plate to dampener. In this configuration it made 700 HP and 600 FT/LB Torque. I have dyno sheets and flow numbers for the buyer and any spare engine related parts ie bearings etc can be negotiated. This engine will go 1 second under and is a proven combination. $ 17,900 US
The more people I meet the more I like my dog Kevin |
