Old 01-19-2018, 03:32 PM   #1
norman saibene sr
Default 321 "SuperStock-Comp Motor
8.300 Aurora Block, Patterson Transmission Plate, Winberg Crank, Honda Journals, GRP Rods, Patterson C.P. Pistons, Diamond Rings, Bullet Cam, 55 M.M. ,Jessel Lifters,Manton Pushrods, Slawco 11 Degree Heads ,7 MM Titanium Valves, , Steffs Pan, Jessel Front Drive, Jessel Distributor, T.D. Rockers, H.R.E. Manifold ,2 Steve Taylor Carbs, M.S.D. CSR Pump, Peterson Wet Sump System, Motor Plate, All Hoses and Brackets ,Ran 8..64 in 2870 Lb Car ,18 Runs,
Dyno and Build Sheet , 900 HP !!! You could not build this for less than $30,000.00
2 convertors for Combination $15,000.00
1 New HRE Manifold 8.300 Deck Manifold for 2 Dominators .$1,500.00
S.B.C. Winberg Crank 2.750 Stroke Perfect Condition $1,350.00
Pics Available!!!!!!!!
Call 330-477-9361 or 330-324-0746 or 234-214-9022
norman saibene sr is offline   Reply With Quote
